Easy LLM with Ollama
Post new topic   Reply to topic    ClassicConnect Forum Index -> Artificial Intelligence
PostPosted: Thu May 08, 2025 11:15 pm    Post subject: Easy LLM with Ollama Reply with quote
Want to install an LLM in a snap? Ollama is pretty solid!
First we need to download and install Ollama.
You can get it here:
Mac - https://ollama.com/download/Ollama-darwin.zip
Windows - https://ollama.com/download/OllamaSetup.exe
Linux
curl -fsSL https://ollama.com/install.sh | sh
Once Ollama is installed.
You will need a model to run. Head here to see the list of models available.
https://ollama.com/search
For this example I'm going to use llama3.3
To pull the model, open up your terminal and type:
ollama pull llama3.3
The model will download and once complete it will be ready to run.
To run the model type:
ollama run llama3.3
The model will load and its then ready for your input!
Other cool stuff for Ollama.
If you want to write scripts that invoke ollama, visit this github and choose between Python and Javascript!
Python - https://github.com/ollama/ollama-python
Javascript - https://github.com/ollama/ollama-js
Be sure to read the github readme for documentation and checkthe example directory for some good usage examples.
What about a web frontend?
To run Ollama using OpenWebUI (Similar to OpenAI's web interface) visit https://docs.openwebui.com/getting-started/quick-start
This will require you to be familiar with Docker.
Have fun!
PostPosted: Thu May 08, 2025 11:19 pm    Post subject: Reply with quote
While I do appreciate the posts, the reason Ollama isn't recommended is because it uses a non standard API (aka its not OpenAI compatible), and Ollama is just a fork of llama.cpp with less features than Koboldcpp, yet they have almost similar levels of ease of use.
PostPosted: Thu May 08, 2025 11:24 pm    Post subject: Reply with quote
For those who don't want to be in the OpenAI sphere, I feel this is a decent alternative. Especially for those who just want to play around with AI and not do anything too in-depth.
Post new topic   Reply to topic    ClassicConnect Forum Index -> Artificial Intelligence All times are GMT
Page generation time: 0.0125s (PHP: 92% - SQL: 8%) - SQL queries: 11 - GZIP enabled - Debug on
