fortran physics calculations
ravenbrook
PostPosted: Mon May 04, 2026 3:21 pm    Post subject: fortran physics calculations Reply with quote
i am a beginner at programming, but i am working on making a basic library of physics equations in fortran. i made one for length contraction, working both ways. i need to add an option to find velocity. just thought some of you might be interested.
program calc
   use, intrinsic :: iso_fortran_env, only : real_kinds, &
 & real32, real64, real128
   implicit none
   character*1 :: type
   real(kind=real128) :: c, v, l, length
   c = 299792458d+0
   print *, "Are you working out contracted length (i) or original length (p)?"
   read *, type
   if( type == 'i' ) then
   print *, "Please enter your velocity: "
   read *, v
   print *, "Please enter the length of the object: "
   read *, l
   length = l * sqrt( 1 - (v / c)**2 )
   print *, 'The contracted length is ', length
   else if( type == 'p' ) then
   read *, v
   read *, length
   l = length / sqrt( 1 - (v / c)**2 )
   print *, 'The original length is  ', l
   else
   print *, "That wasn't an option I gave you was it?"
end if
end program calc
should note that this was compiled as fortran 90
The front fell o- wait what? It didn't fall off? Oh.
ravenbrook
PostPosted: Wed May 06, 2026 3:09 pm    Post subject: Reply with quote
i have improved it by adding an option to calculate starting velocity and just general sanity improvements.
program calc
   implicit none
   character*1 :: type
   c = 299792458d+0
   print *, "Are you working out: "
   print *, "(1) Contracted length"
   print *, "(2) Original length"
   print *, "(3) Velocity"
   read *, type
   if( type == '1' ) then
   read *, v
   read *, l
   l = abs(l)
   else if( type == '2' ) then
   read *, v
   read *, length
   length = abs(length)
   else if ( type == '3' ) then
   print *, "What is the original length?"
   read *, l
   print *, "What is the contracted length?"
   read *, length
   v = c * sqrt( 1 - ( length / l ) ** 2 )
   print *, "The velocity is: ", v
   else
end if
end program calc
(edited the code as i had made some changes)
Page generation time: 0.022s (PHP: 96% - SQL: 4%) - SQL queries: 15 - GZIP enabled - Debug on
