Can i run an LLM from my Windows 7 Win-To-Go setup?
Post new topic   Reply to topic    ClassicConnect Forum Index -> Artificial Intelligence
PatoFlamejanteTV
PostPosted: Fri May 08, 2026 1:36 pm    Post subject: Can i run an LLM from my Windows 7 Win-To-Go setup? Reply with quote
Currently i want to test Ollama on it, but its installed on a SD Card, its velocity is around ~20MB/s (tested by transferring an large file from my Linux setup to it).
It has 32 GB of storage, but windows only used ~7GB, so there's a plenty of storage yet.
Is possible to use Ollama on it? Or i may need to use an software to path the executable before using?
claraberry
PostPosted: Fri May 08, 2026 1:45 pm    Post subject: Re: Can i run an LLM from my Windows 7 Win-To-Go setup? Reply with quote
You'll probably get abysmal loading times, but there's nothing inherently stopping you if you have the hardware.
All operating systems suck equally, it is up to you to decide which you get along with the most
PostPosted: Fri May 08, 2026 3:34 pm    Post subject: Reply with quote
Main limits here would be software support. Barely any LLM software supports Windows 7, only one I know would be Kobold CPP in the old cpu mode. Not to mention, you need a fairly good CPU to get any usable T/s out of it. An i7-3612QM for example, that will run LLama 3.2 3b @ Q4, around 8T/s. MoEs will certainly be helpful, but I wouldn't expect too much out of this. If you do however have something workable, it'll take a long time to load, once it's in RAM though it should be somewhat faster.
ParzivalWolfram
PostPosted: Fri May 15, 2026 6:54 am    Post subject: Reply with quote
I believe the only technical hurdle between you and something like LLaMa is, on paper, a C++17 compiler. I'd expect more work to be needed, but you'd get pretty close with something like MinGW. It'll obviously be CPU-bound, and as such, real damn slow even on a top of the line machine, but it should work.
Post new topic   Reply to topic    ClassicConnect Forum Index -> Artificial Intelligence All times are GMT
Page generation time: 0.0105s (PHP: 92% - SQL: 8%) - SQL queries: 11 - GZIP enabled - Debug on
