europa Gorts
Joined: 16 Aug 2025 Age: 24 Posts: 112 Location: 8:0:20:c0:ff:ee
Posted: Mon Jun 01, 2026 10:40 pm Post subject: Serial Port Issues on Windows 3.11 |
Hi y'all, I have a bit of an interesting issue - I have a PS/ValuePoint 466DX2/Si and trying to use the serial ports oftentimes locks up Windows. I do not have any issues under DOS but, under Windows, the system will hard freeze if I a) try to talk to a serial port when nothing is connected or if the settings are misconfigured, or b) use any program other than the Terminal program (namely the NIST ACTS program and WinFax 4) that accesses the serial ports. I assume this is not intended behavior, but I'm at a loss for what could be wrong, as I have checked and see no resource conflicts (the only potential overlap would be COM1 and COM3, and COM2 and COM4, but my computer only has COM1 and COM2, so I don't believe that should be an issue.
Anyone have any advice? _________________ Your System ate a SPARC! Gah! |
europa Gorts
Posted: Tue Jun 02, 2026 1:17 am Post subject: |
To update this, it seems this was a known issue back in the day, and there was something released to solve this issue. Thanks to Nick for finding this info!
https://ps-2.kev009.com/pcpartnerinfo/ctstips/db1e.htm _________________ Your System ate a SPARC! Gah! |
VCSMaster Disk Central Admin
Joined: 25 May 2025 Posts: 221 Location: Southeastern USA
Posted: Sat Jul 11, 2026 12:02 am Post subject: |
| Very uncharacteristic ending to a forum thread!! You're not supposed to post the link to the solution, the chain of events is always "Question" "I will answer in DMs" "Solved" and then people 25 years later wonder what the heck fixed it! |
europa Gorts
Posted: Sat Jul 11, 2026 4:04 am Post subject: |
Yes! I do my best to post solutions when I find them. I've been bitten by a forum thread with no solution too many times. _________________ Your System ate a SPARC! Gah! |
