[Driver] In Need of a webcam driver
Post new topic   Reply to topic    ClassicConnect Forum Index -> The Workbench
xX_D4rkW1ng_Xx
PostPosted: Mon Apr 13, 2026 12:12 pm    Post subject: [Driver] In Need of a webcam driver Reply with quote
I've bought a PK935 A4 tech webcam, the one that looks like a globe...
but i don't have the driver, yall know where to get it?
Why can't the internet be colorfull again?
View user's profile Send private message Yahoo Messenger MSN Messenger
daniel
PostPosted: Wed Apr 22, 2026 10:10 pm    Post subject: Re: [Driver] In Need of a webcam driver Reply with quote
What OS are you using? From what I found around the net, it's a newer cam and *should* be plug and play.
Otherwise it's a bit scarce trying to find a reliable driver for that camera online. There are a few sites that claim to have it but, idk about how sketchy they are though so it could be risky.
-Daniel
PostPosted: Fri May 08, 2026 2:48 am    Post subject: Reply with quote
Should probably put the OS you're using, but most webcams are just USB imaging devices and should "just work" on anything even approximating modern. My brand new Onn webcam from Walmart was plug and play with Windows XP, to give you an idea.
xX_D4rkW1ng_Xx
PostPosted: Fri May 08, 2026 3:43 pm    Post subject: Reply with quote
I'm using Win10, and "just work" might be accurate to most, not to this one.
I wasn't able to use it straight away, of note is that the driver for the A4tech pk-635m Camera did work with it. But it's still not the driver intended for it, so im still searching...
But yes, it is "working".
PostPosted: Fri May 08, 2026 11:13 pm    Post subject: Reply with quote
Is there any reason specifically you need a special driver for this thing? I'm fairly surprised it wasn't just a generic USB imaging device.
Is this actually something more than a cheap microphone, a CCD, and maybe an autofocus or a light?
Post new topic   Reply to topic    ClassicConnect Forum Index -> The Workbench All times are GMT
Page generation time: 0.0221s (PHP: 96% - SQL: 4%) - SQL queries: 11 - GZIP enabled - Debug on
