xX_D4rkW1ng_Xx Member
Joined: 22 Mar 2026 Posts: 36 Location: Somewhere in Europe. IMs are on Crosstalk.
Posted: Mon Apr 13, 2026 12:12 pm Post subject: [Driver] In Need of a webcam driver |
I've bought a PK935 A4 tech webcam, the one that looks like a globe...
but i don't have the driver, yall know where to get it? _________________ Why can't the internet be colorfull again?
daniel Member
Posted: Wed Apr 22, 2026 10:10 pm Post subject: Re: [Driver] In Need of a webcam driver |
| xX_D4rkW1ng_Xx wrote: | I've bought a PK935 A4 tech webcam, the one that looks like a globe...
but i don't have the driver, yall know where to get it? |
What OS are you using? From what I found around the net, it's a newer cam and *should* be plug and play.
Otherwise it's a bit scarce trying to find a reliable driver for that camera online. There are a few sites that claim to have it but, idk about how sketchy they are though so it could be risky. _________________ Please hesitate to reach out.
-Daniel |
VCSMaster Disk Central Admin
Joined: 25 May 2025 Posts: 221 Location: Southeastern USA
Posted: Fri May 08, 2026 2:48 am Post subject: |
| Should probably put the OS you're using, but most webcams are just USB imaging devices and should "just work" on anything even approximating modern. My brand new Onn webcam from Walmart was plug and play with Windows XP, to give you an idea. |
Posted: Fri May 08, 2026 3:43 pm Post subject: |
| VCSMaster wrote: | | Should probably put the OS you're using, but most webcams are just USB imaging devices and should "just work" on anything even approximating modern. My brand new Onn webcam from Walmart was plug and play with Windows XP, to give you an idea. |
I'm using Win10, and "just work" might be accurate to most, not to this one.
I wasn't able to use it straight away, of note is that the driver for the A4tech pk-635m Camera did work with it. But it's still not the driver intended for it, so im still searching...
But yes, it is "working". _________________ Why can't the internet be colorfull again?
Posted: Fri May 08, 2026 11:13 pm Post subject: |
Is there any reason specifically you need a special driver for this thing? I'm fairly surprised it wasn't just a generic USB imaging device.
Is this actually something more than a cheap microphone, a CCD, and maybe an autofocus or a light? |
