Compaq SLT/286 Restoration
Post new topic   Reply to topic    ClassicConnect Forum Index -> Hardware and Electronics
europa
PostPosted: Wed Apr 08, 2026 8:22 pm    Post subject: Compaq SLT/286 Restoration Reply with quote
I recently came across a Compaq SLT/286 in somewhat decent condition. It was missing the power adapter and battery, and the rear panel has fallen off, but that's nothing that I cannot fix. I wanted to post a thread about getting it back up and running, and restoring it where I can.
For some background, the Compaq SLT/286 was released in 1988 and shipped with a 12MHz 286 processor. It came with 640kB of memory (which is expandable to 12.6MB from what I'm reading), a 20 or 40MB hard drive, a high-density 3.5" diskette drive, a monochrome VGA screen with VGA output, an optional 2400 baud modem that mine does have, and a battery that was advertised to be at least three hours. Additionally, it has a PS/2 keyboard port (not mouse), serial port, parallel port, what seemingly looks to be some manner of proprietary floppy or tape drive port, and an expansion connector that can hook up to a docking station that provides two ISA slots.
The largest priorities for this machine are to back up the hard drive if possible, replace the CMOS battery and clock chip, as it's something like a Dallas chip, and create a power adapter that will work with the unit. I would also like to reattach the rear panel and perhaps find a way to fill the hole in the case where the battery went (or even build a new battery for it), but those are both largely cosmetic issues and don't affect the operation of the unit overall.
Case badge, front, and rear of the laptop, and the laptop fully opened.
The detached back panel and power adapter port.
I look forward to restoring this machine, it's my first 286 machine I've ever owned and it's absolutely beautiful.
Your System ate a SPARC! Gah!
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Wed Apr 08, 2026 9:02 pm    Post subject: Reply with quote
That is a beautiful machine. Looking forward to hopefully seeing it up and running!
europa
PostPosted: Sun Apr 12, 2026 3:24 am    Post subject: Reply with quote
Yes! I'm excited to get it working. Also I think this will be my third hostnameless machine, aside from my Kaypro and my VIC-20, at least unless I network it in some way that requires that it inform a network of a human-readable name.
parasquared
WebTV
PostPosted: Mon Apr 13, 2026 3:30 am    Post subject: Reply with quote
do the other two at least have names? or are they completely nameless Razz
- parasquared
"In space there is no center, we're always off to the side"
- Ballad of Reverend War Character, Silver Jews
europa
PostPosted: Mon Apr 13, 2026 4:36 am    Post subject: Reply with quote
I mostly just refer to them by their model name, mostly because the names are only really there to help me identify them on a network. That being said, it might be fun to come up with names for them Razz
PostPosted: Fri May 08, 2026 3:14 am    Post subject: Reply with quote
Wow, I know someone who needs to see this. Maybe this will convince him to join!
80compaqpc
PostPosted: Sat May 09, 2026 5:13 am    Post subject: Reply with quote
Here I am! Thanks for showing me this!
Excellent find! These are some of my absolute favorite laptops ever. Such a well designed machine with a great form factor. Very durable and reliable machines too. And it was Compaq's first laptop and the first ever laptop to have VGA graphics!
For reattaching the back panel, I recommend removing the motherboard first, because I've seen cases where the tabs on the bottom dig into the motherboard and damage traces when reinstalling it. Many people think you have to take the back panel off before sliding the chassis out, but you do NOT and the service manual never says to do to.
These are not terribly hard machines to work on at all, in fact they are quite easy compared to many other laptops of the era. Compaq's engineering was just amazing in this era.
Here is a link to the official service manual:
https://www.minuszerodegrees.net/manuals/Compaq/Compaq%20SLT286%20and%20SLT386s20%20-%20Maintenance%20and%20Service%20Guide.pdf
As you mentioned, these machines do use a Dallas chip, which is NOT socketed which can make things tricky, but I actually cut into them to expose the battery contacts with a Dremel while still on the board, as they are kind of a pain to desolder since the pics are so tiny. I do NOT recommend that unless you have a steady hand though, as one slip can severely damage the board.
There was someone selling a modern power supply solution on eBay recently, but I'm not sure if they still are or not. The original power supplies can be tricky to find on their own. I have bought entire machines just to get a power adapter before!
For the hard drive, if it's original, it will be a Conner CP-3021, 3021i (20MB) or a CP-3041 (40MB). You have to be careful with these because the gasket/seal melts and can get all over the inside of the drive. If it gets all over the platters then the drive is pretty much toast, but if not, you can clean the mess up, and reseal the drive with silicone. I have many of these I've repaired still going strong. You do have to remove the lid to inspect and clean the drive, but it will not hurt it if you are careful. You also have to inspect the rubber bump stops for the head actuator (located on either side of the magnet) as they will likely have melted too. I just clean these up and leave them off, as these drives don't actually need the bumpers like some others.
Another word of caution for these hard drives, is the foam insulation degrades between the PCB and drive chassis, and in some cases I have had this short out and destroy the PCB, so I also recommend removing the PCB, scraping off the degraded foam and replacing it with some very thin cardboard. All of this should be done BEFORE attempting to power up the drive! This all comes from research and my own experience with these drives over the years. I've had pretty decent luck reviving them and keeping them going with these methods. Many people replace these with modern solid state solutions, but I like my spinning rust personally.
Hope this is of some help! Wish you luck on getting your SLT running!
europa
PostPosted: Mon May 11, 2026 5:06 pm    Post subject: Reply with quote
Wow, thank you for all the info! This will come in very handy. Smile
I'll be sure to keep updating this thread as I work on the computer, it looks like a really awesome bit of kit. Once I get an ATA set up, I'd love to make use of the modem that's in the machine as well.
80compaqpc
PostPosted: Tue May 12, 2026 4:05 am    Post subject: Reply with quote
No problem! Looking forward to seeing the progress you make with it.
Post new topic   Reply to topic    ClassicConnect Forum Index -> Hardware and Electronics All times are GMT
Page generation time: 0.0157s (PHP: 92% - SQL: 8%) - SQL queries: 11 - GZIP enabled - Debug on
